KB80176
Published: September 8, 2008
SuperTrend data not updated and 'Enable Item' Event Log errors
Problem was discovered in version: R8.1a
Problem is fixed in version: R8.2d
A SuperTrend may fail to update or display data at Runtime. The Event Log displays Enable Item errors for each of the SuperTrend's tags. This occurs if the window the SuperTrend is in, is opened at start-up and the SuperTrend Disabled Scanning is set to window is closed, minimized, or both.
[image1]
Close the window with the SuperTrend graphic and re-open the window. The SuperTrend updates data as expected.
