KB80219
Published: September 9, 2008
Background downloaded strategy stored to flash memory may time out
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R8.1d
Problem is fixed in version: R8.2e
If a PAC Control engine is running a strategy and a very large strategy is simultaneously downloaded in the background, the background download may time out. The timeout occurs if a very large strategy is background downloaded, and is then saved to flash memory after the download. A message pops up and reports "Timeout. No response from device. Check hardware connection, address, power, and jumpers. Last command sent: BurnIt ."
Opto 22 has resolved this issue. In version R8.2b, the timeout value was increased to 90 seconds. In version R8.2e, the timeout is increased to 120 seconds.
