KB80222
Published: July 15, 2008
Problems when modifying an 'Append String to String' command in PAC Control
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R8.1d
Problem is fixed in version: R8.2b
Modifying an already configured Append String to String command may cause PAC Control to crash. The problem occurs if the command originally uses two string variables and is then modified to use a string literal in the first parameter. Clicking OK from the Add Instruction window causes PAC Control to crash.
