KB80232
Published: June 26, 2008
Some 'Move Table to I/O Unit' PAC Control commands don't work as expected with mistic I/O
Problem was discovered in version: R8.1a
Problem is fixed in version: R8.2a
Various Move Table to I/O Unit commands do not work as expected with mistic I/O units.
Move Table to I/O Unit: Moving a table with less than 32 elements to an analog mistic I/O unit returns error -12.
IVAL Move Numeric Table to I/O Unit: IVALs are not written to mistic analog and digital input points. Additionally, moving a table with less than 32 elements to an analog I/O unit, returns error -12.
Move Table to I/O Unit Ex: The Points per Module parameter is ignored and the command requires the table length be 8 times that value. Only the first 16 elements of the table are used to write to analog or digital outputs.
IVAL Move Numeric Table to I/O Unit Ex: IVALs are not written to mistic analog or digital input points.
