KB80260
Published: June 26, 2008
'Set Analog Offset' PAC Control command limits offset values
Problem was discovered in version: R8.1a
Problem is fixed in version: R8.2a
The "Set Analog Offset" command limits the offset value (the To parameter) to within a range of +/-4095 counts for mistic analog input points. While this is the count range for G4 mistic I/O, SNAP modules used with B3000 I/O units with mistic protocol, have an offset range of +/-25000 counts.
