KB80275
Published: June 26, 2008
mistic brain totalizer rates truncated by 'Set Analog Totalizer Rate' command
Problem was discovered in version: R8.1a
Problem is fixed in version: R8.2a
The Set Analog Totalizer Rate PAC Control command truncates totalizer rates (the To parameter) that have a fractional value. For example, a totalizer rate of 1.9 is set to a totalizer rate of 1.0.
