KB80285
Published: June 26, 2008
SuperTrend historic log file's date may show 01/02/1601 during Runtime
Problem was discovered in version: R8.1e
Problem is fixed in version: R8.2a
If Use 0.01 Sec. Resolution is not checked in the Historic Log File Configuration window when a SuperTrend is configured, then the displayed start time of the data contained in the file may appear in the SuperTrend Historic Log Files window as 01/02/1601.
[image1]
The SuperTrend Historic Log Files window appears when the Historical mode button is selected from the SuperTrend at Runtime. By default, it lists the names of SuperTrend historic log files and the date and time each log started and stopped recording data. The 01/02/1601 date may be displayed in this window, but it is not the actual date/time of the data recorded.
