KB80296
Published: July 15, 2008
Possible problems using PAC Control pointers with G4D32RS / SNAP-BRS units
PAC Control Professional
Problem was discovered in version: R8.1d
Problem is fixed in version: R8.2c
In PAC Control, possible problems may occur when attempting to assign a pointer from a pointer table with information about mistic Remote Simple I/O units (G4D32RS and SNAP‑BRS).
For example, the following OptoScript code should work. Instead, an error -29 occurs at strategy Runtime:
pRemoteSimple = &MyRemoteSimple;
MyPtrTable[0] = pRemoteSimple;
pRemoteSimple = MyPtrTable[0]; // This line causes an error at Runtime
