KB80310
Published: July 15, 2008
Using 'Modify' from I/O point in Strategy Tree may cause odd behavior
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R8.1a
Problem is fixed in version: R8.2b
Odd behavior may result from right-mouse clicking a point in the strategy tree on a PAC I/O unit and selecting Modify. The unexpected behavior occurs if the point is configured to be in the upper 8 module positions of the mounting rack (point numbers above 256). Depending on what is configured on the I/O unit, PAC Control may crash, do nothing, or have other unexpected results.
