KB80311
Published: July 15, 2008
'TPO' digital output feature in PAC Control Basic
PAC Control Basic
Problem was discovered in version: R8.2a
Problem is fixed in version: R8.2c
When configuring digital output points in PAC Control Basic Configure mode, the TPO feature is incorrectly available from the Features: field in the Edit Digital Point dialog. Since the TPO feature should not be availble from PAC Control Basic, there are no supporting commands available, such as Set TPO Period or Set TPO Percent.
