KB80318
Published: July 15, 2008
Clicking graphic only toggles once in PAC Display
Problem was discovered in version: R8.2a
Problem is fixed in version: R8.2b
The dynamic attribute for Send Discrete, Fixed data, Toggle of an integer bit, only works the first time the configured graphic is clicked. Subsequent clicking on the graphic are unresponsive. If the window with the configured graphic is closed and re-opened, then the graphic will again work the first time it is clicked.
[image1]
