KB80347
Published: July 30, 2008
Alarm sound doesn't play if Persistence Time is configured
Problem was discovered in version: R8.2b
Problem is fixed in version: R8.2c
An alarmpoint set up to play a sound when an alarm is active and that has a Persistence Time configured, does not play even if the point is still in alarm after the persistence time expires. The persistence time is the length of time to wait before a point is considered to be in an alarm condition. (Persistence time is configured from the Configure AlarmPoint dialog (Configure→Alarm Points, Setup by Discrete, Discrete tab, More... button, Configure Persistence Time.)
