KB80362
Published: September 8, 2008
'PID type "input" not currently supported' message from upgraded OptoDisplay project
Problem was discovered in version: R8.2c
Problem is fixed in version: R8.2d
The Tools→ IO Scanner Tag Names command reports the error message PID type "input" not currently supported" if an older MisticMMI or OptoDisplay project is migrated to PAC Display, and it has a PID Process Variable tag. As a result, a tag for the variable is not created.
