KB80364
Published: August 18, 2008
Problems opening PAC Manager R8.1 .otg files with R8.2
Problem was discovered in version: R8.2a
PAC Manager R8.2a cannot open PAC Manager configuration files (.otg files) created in version R8.1.
To work around this problem, edit the .otg file with an application such as NotePad. For each IOUNIT, change the sixth parameter from "0" to "8" as shown below.
[image1]
Opto 22 is aware of this issue.
