KB80365
Published: December 5, 2008
Writing to Mistic PID output has no effect on the analog output
Problem was discovered in version: R8.2a
Problem is fixed in version: R8.3a
If a value is sent from PAC Display, PAC Control Debug mode, or OptoOPCServer to a Mistic PID analog output, there is no effect on the output from the analog module. The controller IVAL is changed, but not the XVAL. Mistic PIDs may be configured on B3000, G4A8R, G4A8RAX, and B200 I/O units.
The following image is an example of a Mistic PID output tag selected for a PAC Display graphic's dynamic attribute.
[image1]
