KB80368
Published: September 8, 2008
Can't write to PAC Display PID tags upgraded from Mistic MMI or OptoDisplay
Problem was discovered in version: R8.2c
Problem is fixed in version: R8.2d
The Send Value and Send Discrete commands cannot successfully send data to PID tags that originated from Mistic MMI or OptoDisplay projects. Attempts to send data at Runtime displays a message similar to the following in the Event Log Viewer:
TValue() Error: Referenced Type: <type> Actual Type: <type>
The wording for <type> depends on the type of tag written to (integer, float, etc.).
