KB80374
Published: December 5, 2008
'Get & Restart Period' command returns zero for period measurement
SNAP-PAC-EB1
SNAP-PAC-EB2
SNAP-PAC-SB1
SNAP-PAC-SB2
Problem was discovered in version: R8.2a
Problem is fixed in version: R8.3a
The Get & Restart Period command may return a 0 even after the Get Period Measurement Complete Status command returns a true response, and is used to determine if the period measurement is complete. The period measurement is not actually complete, and results in a partial period measurement (or a 0).
Add a delay after the Get & Restart Period command, and before the next Get Period Measurement Complete Status command. The delay should be the Digital Features Scan Interval value + 1 ms. Use PAC Manager to inspect this value with Tools→Inspect, Status Write. For an I/O unit with a 1 ms delay as shown below, the delay would be 2 ms.
[image1]
