KB80379
Published: September 16, 2008
Problems with the 'Enable Communication to Mistic PID Loop' command
PAC Control Professional
Problem was introduced in version: R7.0a
Problem is fixed in version: R9.5b
After adding the Enable Communication to Mistic PID Loop command to an Action block, the command appears as Enable Communication to PID Loop. When the strategy is compiled, a compile error similar to the image below, is shown.
[image1]
Use an OptoScript block instead of an Action block to add the command. The equivalent OptoScript command is EnableCommunicationToMisticPidLoop(PID Loop).
