KB80385
Published: December 22, 2008
PAC Simulator's 'Store to Flash' doesn't work under Windows Vista
SNAP PAC Sim Control Engine Simulator
Problem was discovered in version: R8.2a
Problem is fixed in version: R8.3a
A strategy is not saved to PAC Simulator's "flash memory" when run under Windows Vista. The strategy must be re-downloaded each time Simulator is started. The image below shows how to save the strategy to flash from PAC Control Configure mode (File→Strategy Options, Download tab).
[image1]
