KB80409
Published: October 28, 2008
Problem with SNAP-PAC-S2 serial port's DCD signal
Problem affects loader versions: R4.0a, R4.0b, R5.0a
Problem is fixed in loader versions: R4.0c, R5.0b and newer revisions
The SNAP-PAC-S2's Data Carrier Detect (DCD) signal on serial ports 2 and 3 may be inverted due to a bug in the loader firmware. The DCD signal appears ON when it is OFF, and appears OFF when it is ON. This problem only occurs after a power cycle, but does not occur after every power cycle. Once it occurs, it persists until power is cycled. The Reset to defaults and Restart Device operation from PAC Manager (Tools→Inspect, Status Write) and the controller's RESET button, do not clear up the problem.
Opto 22 has corrected this problem.
