KB80420
Published: December 17, 2008
When 'Change IP Settings' does not set IP address to 0.0.0.0
PAC Manager
Problem was discovered in version: R8.2c
Problem is fixed in version: R8.2d
The Change IP Settings dialog may not allow an IP address to be changed to 0.0.0.0 on an Opto 22 device interface. Recent changes in PAC Manager cross-check ENET1 IP information against ENET2 IP information, and prevent the address change if one of the ports (typically ENET2) is already set to 0.0.0.0.
Below, is an example of the message reported when the IP assignment is prevented.
[image1]
