KB80434
Published: November 24, 2008
Changing SNAP analog ouput module scaling may cause rare, infrequent reset
SNAP-PAC-EB1
SNAP-PAC-EB2
SNAP-PAC-SB1
SNAP-PAC-SB2
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-ENET-S64
SNAP-B3000-ENET
Problem was discovered in version: All versions of SNAP PAC
All others, R6.0a
Changing the upper or lower scaled units for an analog output point may cause a rare, infrequent module reset.
When the problem occurs, the Smart Modules Present mask in PAC Manager momentarily indicates the module is offline, and the module's Times Discovered count from the Inspect Opto 22 Device page (Tools→Inspect, Status Read), increments by one.
