KB80439
Published: December 18, 2008
PAC Display may crash on exit
Problem was discovered in version: R8.2e
Problem is fixed in version: R8.2f
PAC Display Runtime crashes on exit if the Yes button from the Exit PAC Display Runtime window is selected using the <Enter> key.
Use the mouse or the space bar to select Yes to exit normally.
