KB80441
Published: December 18, 2008
Regenerate IO Scanner Tag Names skips the Append String tag for Launch Application dynamic attribute
Problem was discovered in version: R8.2e
Problem is fixed in version: R8.2f
Clicking a graphic in Runtime configured with the Launch Application dynamic attribute and the Append String tag, may return an error.
To correct the problem, use Configurator to reselect the Launch Application dynamic attribute, and reconfigure the Append String Tag. After saving the project and loading Runtime, the configured graphic operates as expected.
