KB80443
Published: December 17, 2008
Narrow XY Plots drawn incorrectly
Problem was discovered in version: R8.2e
Problem is fixed in version: R8.2f
Points are drawn below an XY Plot at Runtime when a plot is narrow (width, W, is about 250 pixels or less) and one or more pens are configured with the Show Legend in Runtime option. This problem is not seen if none of the pens have this option set. Normally, points below the plot's Y range are clipped at the lower edge.
