KB80467
Published: December 18, 2008
Runtime crashes if graphic is clicked before its window closes
Problem was discovered in version: R8.2e
Problem is fixed in version: R8.2f
If a window is set (triggered) to close, but a graphic from that same window is clicked before the window is visually closed, Runtime crashes. The graphic clicked must be configured with an Operator Driven Dynamic Attribute for this problem to occur.
