KB80493
Published: February 5, 2009
'IVAL Move Numeric Table to I/O Unit' commands don't work with some I/O units
Problem was discovered in version: R8.2a
The IVAL Move Numeric Table to I/O Unit and the IVAL Move Numeric Table to I/O Unit EX commands, only work with analog output points on Ethernet type of I/O units, and do not work with analog input, digital input, and digital output points. The commands work as expected with Mistic I/O units.
Set the IVAL for an individual point using the commands available from the PAC Control, Simulation group. For analog points, use IVAL Set Analog Point. For digital points, use the IVAL Turn On, or the IVAL Turn Off command.
