KB80502
Published: March 24, 2009
PAC Control's 'Inspect I/O Unit' reports incorrect values for some I/O combinations
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R8.2e
Problem is fixed in version: R8.2f
In Debug mode, some I/O module combinations may cause the Inspect I/O Unit dialog to display incorrect IVAL and XVAL values.
Here are some examples of the I/O configurations that cause this problem:
- No digital modules present on the rack.
- 4-channel analog modules in the lower 8 module positions on the rack.
Example: A SNAP-AIMA-4 analog module in rack position 0.
- High-density analog modules in the upper 8 module positions on the rack.
Example: A SNAP-AIV-8 in rack position 8.
