KB80503
Published: March 9, 2009
Controllers report incorrect values for some I/O combinations in 'Inspect I/O Unit'
Problem was discovered in version: R8.3a
Problem is fixed in version: R8.4a
Incorrect values for IVALs and XVALs are reported by the Inspect I/O Unit dialog in PAC Control debug mode if there are certain I/O configurations present on the I/O rack. The following examples demonstrate some of these configurations:
  • No digital modules present on the rack.
  • 4-channel analog modules in the lower 8 module positions on the rack.
    Example: A SNAP-AIMA-4 analog module in rack position 0.
  • High-density analog modules in the upper 8 module positions on the rack.
    Example: A SNAP-AIV-8 in rack position 8.
Opto 22 has resolved this issue. See also Opto KB80502 regarding a related bug in PAC Control.
