KB80534
Published: April 24, 2009
Breakpoint "hand" invisible in subroutines when returning to Debug mode
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R8.2e
The Debug mode breakpoint "hand" is invisible on subroutine blocks, but the logic flow behavior is as if the breakpoint is present.
This problem occurs when breakpoints are set up in a subroutine, you return to Configure mode, and just before leaving Debug mode, select No when asked about clearing the breakpoints. When you return to Debug mode from Configure mode, the breakpoints are invisible.
[image1]
To clear the invisible breakpoints, return to Configure mode. When asked about clearing the breakpoints before leaving Debug mode, select Yes from the dialog box. The invisible breakpoints are removed.
