KB80536
Published: March 24, 2009
Runtime text data may be incorrect if window has non-consecutive refresh groups
Problem was discovered in version: R8.2f
Problem is fixed in version: R8.2h
Runtime text data may be incorrectly displayed in a window with tags that have non-consecutive refresh groups.
To reproduce the problem:
  1. In PAC Display Configurator, add 3 text graphic objects to a window.
  2. Assign the first text object the dynamic attribute Text In from Control Engine, and assign it a tage with Refresh Group 0.
  3. Assign the second text object the dynamic attribute Text In from Control Engine, and assign it a tag with Refresh Group 2 (notice Refresh Group 1 is skipped).
  4. Assign the third text object the dynamic attribute Text In from Control Engine, and assign it a tag with Refresh Group 3.
  5. Save and load Runtime.
The text object value for Refresh Group 0 is correct. But the values for text objects with Refresh Groups 2 and 3 are incorrect, or will be shown as ## signs.
