KB80542
Published: July 20, 2016
PAC Control: "Undefined Command" on download when actual upper and lower scaling values are the same
PAC Control Professional
PAC Control Basic
R8.2f through R9.4e
R9.5a
For analog points, if the Actual Upper and Actual Lower scaling values are both set to the same value, then when downloading the strategy, PAC Control displays an error message that starts with: "Undefined Command." The name of the analog point will be listed in the error message.
Change either the Actual Upper or Actual Lower scaling value.
