KB80553
Published: March 24, 2009
Pointer variable tags reference the wrong tag in Browser Configurator
OptoOPCServer
Problem was discovered in version: R8.2b
Problem is fixed in version: R8.2c
Browser Configurator incorrectly imports pointer variable tags from a PAC Control controller database file (.idb), into a browser database file (.bdb). The first pointer tag references the last string variable instead of the desired pointer tag. The second pointer tag references the tag that should have been referenced by the first pointer variable, and so on.
