KB80555
Published: May 12, 2009
Integer values >16,777,215 may cause inaccurate fill color in PAC Display
Problem was discovered in version: R8.2g Runtime
Problem is fixed in version: R8.2j Runtime
The fill color dynamic attribute for a graphic may be inaccurate if its tag is an integer greater than 16,777,215 (0xFF FFFF). If the fill color is configured to change based on a cutoff value greater than 16,777,215, then the color change may not occur as expected. The problem stems from values being rounded (by PAC Display), resulting in inaccurate comparison values.
