KB80556
Published: June 15, 2009
Save Project and Load Runtime may fail when Runtime is already running
Problem was discovered in version: R8.2h
Problem is fixed in version: R8.2k
If changes are made to a PAC Display project in Configurator while Runtime is running, and Save Project and Load Runtime is used to go back into Runtime, then # signs replace the data in the window.
An error similar to the following appears in the Event Log Viewer:
Server: =>Could not remove group "Your_Group_Name" from server
Exit Runtime and then use Save Project and Load Runtime to go back into Runtime. Data is now correctly updated in the window.
