KB80557
Published: April 16, 2009
PAC-S RS-232 ports unresponsive when used with Mistic I/O units
Problem was discovered in version: R8.4a
SNAP PAC S-series controller RS-232 ports are unresponsive when used to communicate to Mistic I/O units. The RS-232 port's transmit LED (TX0TX3) is active (lights) when the controller initially attempts a serial connection. Subsequent attempts to connect serially results in no activity from the port's transmit LED.
For example, the problem occurs in an application where a modem is connected to the controller's RS-232 port (Port 03) in order to communicate to a remote serial (RS-485) Mistic I/O unit. The remote Mistic I/O unit communicates to the controller's RS-232 port via an RS-232 to RS-485 converter, and then through a modem.
Both Mistic ASCII and Mistic binary protocol exhibit the problem.
