KB80597
Published: September 24, 2009
FTP 'ls' or 'dir' command causes brain to reboot
SNAP-PAC-EB1
SNAP-PAC-EB2
Problem was discovered in version: R8.4a
Problem is fixed in version: R8.5a
If a directory listing of the brain is obtained via FTP using the ls or dir commands using a typical FTP client, then the brain's STAT LED will blink red 5 times and the brain will reboot.
Here is one way to reproduce this problem:
- From the Windows Start menu, choose Run.
- Type ftp://brain ip address as shown in the example below.
[image1]
- Click OK. The status LED will blink 5 times and the brain will reset.
This problem has been fixed.
