KB80621
Published: May 12, 2010
Opening a UDP connection too soon in a strategy may return error -443
Problem was introduced in version: R1.0
Problem is fixed in version: R8.5c
Opening a PAC Control UDP communication handle (udp:<port>) too soon after starting a strategy, may cause error -443 (error on socket receive). For example, after starting a strategy and opening a UDP port, using the GetNumCharsWaiting command may return error -443.
Add a 600 ms delay at the start of the strategy before opening a UDP connection.
