KB80626
Published: September 23, 2009
Problems with Ethernet IP multicast address algorithm for implicit connections and multiple interfaces
Problem affects versions: R8.3a to R8.4a
Resolution is included beginning in version: B8.4b, build date 07/20/2009 and after
Problem is fixed in version: R8.5a
The algorithm that allocates multicast IP addresses for implicit connections only uses the first non-zero IP address found on the IP interfaces in the following order:
- ENET 1
- ENET 2
The algorithm should instead use the IP address assigned to the interface over which the multicast packets will be sent.
This problem has been fixed.
