KB80627
Published: May 28, 2010
OptoControl's 'Write Numeric Table to I/O Memory Map' to SNAP PAC returns -3
G4LC32
G4LC32SX
SNAP-LCSX-PLUS
SNAP-LCSX
M4
M4RTU
G4LC32ISA
G4LC32ISA-LT
Problem was discovered in version: R4.1c
Resolution is included beginning in version: B4.1g
When an OptoControl controller uses the Write Numeric Table to I/O Memory Map command to write to a SNAP PAC I/O unit and the table length is 64 or greater, a status code -3 is returned.
Use tables with a length of 63 or less when using the Write Numeric Table to I/O Memory Map command with OptoControl controllers.
