KB80642
Published: September 10, 2009
'Rotate' attribute for line object and integer tag causes problems at Runtime
Problem was introduced in version: R8.2j
Problem is fixed in version: R8.2m
Applying the Rotate control engine driven dynamic attribute to an integer tag for a line object, may cause PAC Display Runtime to hang when the window with the configured tag is opened.
