KB80657
Published: August 27, 2009
SNAP-Custom-AI points are not scaled correctly by PAC Manager
Problem was discovered in version: R8.2f
PAC Manager sends incorrect scaling information for these custom analog input point types when they are configured from a configuration file (.otg file):
SNAP-CUSTOM-AI: Mode 1 (Scalable)
SNAP-CUSTOM-AI: Mode 2 (Scalable)
SNAP-CUSTOM-AI: Mode 3 (Scalable)
SNAP-CUSTOM-AI: Mode 4 (Scalable)
As a result, readings are not as expected.
Manually configure scaling by using the Point Config button from the Inspect Opto 22 Device window. Set the scaling by using the Upper Scaled Units and Lower Scaled Units parameters, and then click Apply.
A fix for this problem will be included in an upcoming release.
