KB80664
Published: May 12, 2010
Controllers talking to Ethernet I/O units on high-latency networks may randomly lock up
Problem was introduced in version: R8.4a
Problem is fixed in version: R8.5c
A controller running a PAC Control strategy may become unresponsive if OptoMMP commands (any I/O commands to Ethernet I/O units) are used to communicate to I/O over a high latency network (such as a network that uses radio modems). The chart with the OptoMMP command may hang, the strategy cannot be stopped, and if the Stop Strategy command is sent, the controller's host task becomes locked. Cycling power to the controller corrects the problem.
For example, the strategy may hang on a block with an OptoMMP command in Debug mode. Debug mode reports the chart is still running, but there is no response to attempts to inspect variables or I/O, yet the I/O can be inspected with PAC Manager. Turning power off and then back on corrects the problem.
