KB80672
Published: June 25, 2010
Historic Logs using Start Triggers do not initially log data
Problem was discovered in version: R8.2m
Resolution is included beginning in version: B8.2n, Build date September 22, 2009
If a historic log is configured to use a Start Trigger, when the trigger is activated during PAC Display Runtime, the tag value is read but is not immediately logged. The value is not logged until it's time to scan the data again based on the Refresh Time.
Example: A historic log's Refresh Time is configured to log once every hour. When the Start Trigger is activated, Runtime scans the log variables, but does not log the values until an hour later when it's time to scan the historic log variables again.
