KB80673
Published: June 25, 2010
Adjustable alarm points not logged correctly in Runtime Operator Log File
Problem was discovered in version: R8.2m
Adjustable alarm points configured with floating point tags, are not logged correctly to the Runtime Operator Log File after the alarm point value is adjusted. The tag value is correctly modified in Runtime, but the newly adjusted value is not logged and the original value is logged twice instead.
For this problem to occur, the Operator Adjustable setting has to be checked in the Alarm Point dialog (Configure→Alarm Points, Add/Modify, Setup by Value, Value tab).
Also, the Runtime Operator Logging File option must be checked (Configure→Runtime, Security tab):
