KB80687
Published: May 12, 2010
Controller in backgound download mode fails to run strategy on inserted microSD card
Problem was discovered in version: R8.5a
Problem is fixed in version: R8.5c
A controller does not autorun a strategy from a microSD card when it's inserted into the memory card slot, even though the controller has been configured to autorun and use background downloading.
Instead, the strategy is downloaded to the controller, but is not made active.
To use background downloading and run the strategy on the microSD card, switch to the strategy on the card by using the Inspecting window in PAC Control from debug mode. In debug mode, select PAC Inspect →Control Engine, and select Switch and Run in the Alternate field.
