KB80692
Published: June 25, 2010
The focus frame around a text graphic disappears at Runtime if the send string is empty
Problem was discovered in version: R8.2a
The focus frame around a graphic disappears at Runtime when a Prompt for data string tag is assigned an empty string. As a result, the text area cannot be selected and a string cannot be entered and sent to a controller.
This problem occurs if a string object is configured with these attributes: the Focus-frame enabled, the Send String and Text In from Controller dynamic attributes, and the Prompt for data as the Source. The Send String and Text In from Controller dynamic attributes are also assigned to the same tag.
