KB80700
Published: March 19, 2012
PAC Simulator IVAL On/Off Latch Set commands don't work with High Density digital input modules
SNAP PAC Sim Control Engine Simulator
Problem was discovered in version: R8.1b
Problem is fixed in version: R9.0b
The PAC SIM Control engine IVAL Set Off-Latch and IVAL Set On-Latch commands do not work with high density digital modules (such as SNAP-IDC-32). The command does not write the desired value to the internal value (IVAL) of the digital point's latch input.
