KB80730
Published: May 12, 2010
Control engine STAT LED remains turned off if Scanner flag used to stop strategy
Problem was discovered in version: R8.5a
Problem is fixed in version: R8.5c
If the value 8 is written to a control engine's Scanner Flag, then the control engine's STAT LED turns off and does not turn back on. Writing the value 8 to a control engine's Scanner Flag stops the strategy that is running in the control engine.
