KB80740
Published: June 25, 2010
Edit > Replace, Table Index 'Offset By' option causes non-table tags to appear as tables
Problem was discovered in version: R8.2m
The Configurator Edit > Replace function causes non-table tags to appear to have an index if the Table Index Offset By option is used.
Example: Suppose there are 2 tags, one an integer table tag called MyTable[0] and the other an integer tag called BottleCount.
Entering Offset By 1 causes integer tag BottleCount to appear as BottleCount[1].
